Author Topic: CoolEdit Nostalgia visualizer  (Read 35178 times)
Thanks for 1.7.  Haven't used the phase measurement additions yet but will give them a whirl soon.
"Cosmetic:"  One thing I noticed right away is the new "Zoome" (sp?) button that appears to return a zoomed display to normal.  To be honest I find that visually obtrusive, and would prefer just checking or unchecking the "Zoom selection" choice in the menu.  Also, would it be possible to always recall the last zoom percentage when going from zoom off to zoom on, to save having to redraw the selection each time?  Thanks!
kamen
Hi sveakul!
The GDI version is eating up the last letter in some cases. Try chaning the grid font size as guick fix.
I needed such type of a button for the hold functionality, but it might not be optimal for the zooming as you say...
I'll put that on the list. A quick fix is to save two themes - with zoom and without zoom, and switch between them.
Thank you!
@kamen, very impressed, how your project has grown in half a year!
