So I guess this topic is intended to boil down to:
- what other software tools are you using to prepare your music files before allowing them into heaven?
- what do you believe to be the advantages of the tool that you are using over other tools that you have tried?
Roughly:
First to Foobar2000 (mostly for it's discogs plugin, whjich I've used for a good 10+ years, so to stay true to the formatting/field names etc from there, and a few mass edits that are more difficulkt to do in MB than foobar,)
Then Musicbee for self set/authored tags (rating, and a few custom tags like genre, instruments, instrumental/riddim/version, energy, etc)
The off to DJ programs if needed (i.e Traktor & Serato) for BPM & Key analysis & beatgridding.
Then back to Musicbee (which then gets fed the BPM & Major Key info)
that woul dbe the general workflow.
There was the odd case where I useed mp3tag for functions that were easier in there, compared to Foobar & MB.
Also - I'd love to add Picard to the mix, but, there's no way I will add another hand-holding step to the above... it's borderline as it is already... so I'm hoping that one day I can derive/cross link picard releases from discogID fields, and shove the musibrains data into custom fields from there... but there's still a fair few bits missing to make that possible afaik.
Churs.
c.
