To pre-empt some questions:
* What output mode are you using?
* What format are the files in?
Hi, thanks for the reply.
1) Output mode is WASAPI (Shared)
2) Files are in WAV and FLAC (WAV originally, converted to FLAC, tried both)
It may also help if you can upload one of the problem files somewhere.
Also, see if this is relevant:
https://getmusicbee.com/forum/index.php?topic=35548.msg194413#msg194413
After reading the thread you linked I tried WASAPI (Exclusive) and that does allow to play them correctly (thank you!), but this results in not being able to use the audio for anything else whilst MusicBee is playing which is not what I want.
foobar2000 can play multichannel audio in non-exclusive mode, why wouldn't MusicBee be able to do the same?
