Author Topic: Shuffle Playlist through Command Line  (Read 2086 times)
Kadisra
Hi!
I want to create a shortcut on my Stream Deck to play my favourite playlist shuffled. The easiest way was through the command line, though there is only the way to play it unshuffled. Even if MusicBee is set to shuffled before using the command or use the /PlayLibraryShuffled command before it, doesn't work. The playlist won't shuffle the tracks any way I try. So now I'm using VLC which has this function.
Can this be implemented in MusicBee? It would be nice to just use one program for listening to music.
+1, just because it should be very easy to implement (as far as i understand).
for v3.6 i have added a "/Shuffle" option eg. MusicBee "playlist.mbp" /Shuffle
Last Edit: July 24, 2023, 11:58:26 AM by Steven
