I have a Moto G4 phone running Android 7.0 and was hoping to be able to sync my MB library to it.
I have searched around numerous forum threads already and cannot find a solution to my problem.
I have patched MB to version 3.5.8582
I connect my phone to my PC (Windows 10) via USB with MTP mode. The phone is unlocked, visible and accessible in Windows explorer.
I then open MB but it does not appear under Devices in the left sidebar.
It also does not appear under Computer in MB.
In the Devices preference menu, it shows up in the Add Virtual Device folder browser, however when I select any folder on the phone the OK button is greyed out.
In the error log, this line is printed whenever I connect the phone, or start MB with the phone connected.
Unable to initialise device=Could not load type 'PortableDeviceApiLib.PortableDeviceFTMClass' from assembly 'Interop.PortableDeviceApiLib, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null'.
I have tried different USB ports and reinstalling phone USB drivers.
I'd really appreciate some help with this. Thank you.
