Author Topic: Error when saving artwork to song  (Read 480 times)
Famas115
When I save artwork to a song or try to edit the start time/end time, I get this error message
https://imgur.com/a/tPvV2Kx
Have you white-listed MB in your security software?
Famas115
I only have the standard Microsoft security installed and I have added MB to the exception list
which folder do you have the musicbee library installed (usually Music\MusicBee\MusicBeeLibrary.mbl) and did you check you have write permissions to that folder using windows explorer?
What version of MB are you using? (Help > About) INCLUDE THE LETTER (if any) AFTER THE NUMBER
