I'm trying to import an iTunes library that's located on another drive (in this case F:\), but I keep getting the following error:
MusicBee v3.5.8447.35892D (Win10.0), 2 Jul 2023 23:26:
at #=zPvI1Uy1iDbZdVUmqNyClZIw=.#=zJjo879c=.#=zAhEkRUCkeoEC(List`1 #=z$oIKOWB5JiFY, List`1 #=zpFkLU24jXO5yMX0NNg==, Boolean #=zE0cU$MnDN0fBjzGNjA==, Boolean #=zJ7bRWknvEV$y0rqvYQ==, #=zrJ5_Yk545gE24AxRB8KtbsPWnxrZLt9$1A== #=zYtAAzMnJat_d)
at #=zPvI1Uy1iDbZdVUmqNyClZIw=.#=zJjo879c=.#=z$Vmki7$ws87LvJrGQ9Te5mY=(#=z4$90odPQW5oVh9588w== #=zjbAjPZVG_glF, Boolean #=zE0cU$MnDN0fBjzGNjA==, Boolean #=zJ7bRWknvEV$y0rqvYQ==, #=zrJ5_Yk545gE24AxRB8KtbsPWnxrZLt9$1A== #=zYtAAzMnJat_d)
at #=zmjNyQKFg7RoBdN6C9E9rbVieJ_HH.#=zGZQYi0oQfLfT()
I have a fresh install of Musicbee and was hoping to transition to it as a replacement for iTunes, but unfortunately I can't seem to even get my music out of the program because of this error. AFAIK, my iTunes Library.xml file is formatted correctly, although the library itself is admittedly quite old--I've transferred it across Macs and PCs since at least 2008--could it be that an mp3 file somewhere is corrupted? The library has 5000+ songs so I admit I'm not exactly sure where to begin looking.
I exported a fresh copy of the library XML just to be safe and still ran into the same problem when I attempted importing it into Musicbee again. I'm out of ideas as to what the issue may be. Any help with this would be much appreciated. Thank you!
