Author Topic: Re-request: Pitch control in main view.  (Read 3977 times)
you can also add a panel for pitch or for sample rate
edit:
there might be a bug and i will check it out tonight. Adding one panel, restarting MB and adding the next panel might work
Last Edit: October 08, 2023, 09:28:33 PM by Steven
aktor
Now it works. Something similar like 3 band equalizer anchored in the side panel would be much appreciated.
