Author Topic: Date Created search  (Read 1922 times)
SpirosG
When searching for tracks with an empty 'Date Created' tag (DATE CREATED IS ""), using the middle click in MusicBee library, it doesn't return any results, even though there are tracks without any information in this tag.
The advanced search works flawlessly for tracks with no value in this tag.
 It used to work in the past, so I suspect it may be a bug.
thats fixed for the next v3.5 patch update
SpirosG
Seems like it's broken again.
What version were you using when it was recently fixed?
What version are you using now?
SpirosG
It was fixed in the patch that got released after i opened the thread, seems it broke again after the two or three latest patches.
I'm using the latest patch.
SpirosG
