Hi, I'm loving MusicBee so far and I'm nerding out every evening sorting out my library. However I encountered an issue where, in the music explorer tab (it doesn't happen in others), the displayed album art is different than what I'd like it to be and I can't seem to find the pattern. The album uses one of the tracks' single artwork.
First off, in my preferences the order is Embedded -> back -> artwork -> front. I disabled cover.jpg completely as all my music has embedded art. The others (like back) were used to experiment to see if I set an additional back cover, maybe it would take priority.
Second, the track that "provides" the single artwork is not in the 01. position but rather in 02. I reckon I'd mention it since I saw somewhere that the first track decides the album art.
Lastly, there is one solution I found - which is to set the problematic track's back cover slot (the album art) as the primary cover. However I would like to avoid it, as I'd like it to keep the single art in isolation and only fix how the album art is displayed.
PS. To clear the confusion about why "Saving Lives" shows up twice, I'm using an .asx file to duplicate it in the music explorer view. I don't think it has an impact though, as the single version is the .asx, while the original file is on the album.
