Hi All,
I'm trying to export multiple settings in Music Bee to be able to do a one or two click import on another computer.
Skin, layout settings and the auto-playlists.
I'm using MusicBee at my gym. For our fitness classes, we run the following playlist with tracks that I custom made:
A Track from our Warm Up folder
2 tracks from the Workout folder
1 track from the Transition folder
2 tracks....
until the cooldown.
We are opening another location and I wanted to know if I can export this auto-playlist with the credentials to a file where another copy of Music Bee on another computer can just import it (as long as their music tracks are in the same file/folder structure as my current). Or where is the autoplaylist data stored in the C:/program files/Music Bee folder?
Aside from that, we use a dark skin with large buttons because it helps the instructor. Can that be exported too (the skin and the layout settings)?
Thank you!
