Hi Phred,
thanks for your comment and justified remarks.
Good point to check the version number!
I checked a couple of things ...
MB current download from website:
MusicBee 3.5.8698Released on October 25, 2023
I get the same version info in "About MusicBee" with the "old" files, i.e. unpatched.
(I had copied and put aside the original files before patching and just tested that).
MusicBee 3.5.8778 is the version info after patching (regardless May 20, 2023 or Jan 16, 2024).
I also compared the files from the May 20, 2023 patch (downloaded before my first post) against the ones in the zip provided yesterday. Same size zip, and same size and modification date of all 23 files in the zips. Must be the same patch.
I conclude that I have patched MB successfully, yet still get the results as demonstrated.
[edit] just noticed that there's a "MusicBee36_Patched.zip" to be found under
https://getmusicbee.com/patchesThe zip contains only the MB exe and a plugin. I applied it and the version number is still 3.5.8778 and no change to the problem.
[/edit]
And there's something else ... when clicking the custom rating tag in the track list, "sometimes" the following error is thrown (patched and unpatched, I post both below):
UNPATCHED:
MusicBee v3.5.8698.34385D (Win10.0), 16 Jan 2024 22:33:
at #=z8mB0Fz3gRyk8qBovNJ28mMU=.#=zAZqLRMvzyo5F.#=zPVQzk3oz$qZ8(MouseEventArgs #=zK60pSUM=)
at #=zt5kC_QUQpputtcn$QshTvmU=.#=z736DGfnq_ItJ.OnMouseDown(MouseEventArgs #=zK60pSUM=)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at #=zjZcuVJ9KFZhdDg0h0npILj0=.WndProc(Message& #=zUkWzezk=)
PATCHED:
MusicBee v3.5.8778.33537D (Win10.0), 16 Jan 2024 22:36:
at #=z5e7_4uuh$HfAwio_Tm9cUp0=.#=zL4FmKnJZ65vV.#=zvR$nB1MV2HCo(MouseEventArgs #=zqECjfPg=)
at #=zE6YBU4y2wooHvgf9T9QQykg=.#=zBiRIfrVx2F5a.OnMouseDown(MouseEventArgs #=zqECjfPg=)
at #=zMaPzD13qqrKN7bfWCRzs5nU=.WndProc(Message& #=zppTazko=)
