Author Topic: A-Z Jump Bar  (Read 2311 times)
HappyCamper
Hi All,
I've got my main panel configured to show:
1. A-Z Jump Bar
2. Track Browser
3. Artwork
When I select a letter in the A-Z Jump Bar, the first album-artist starting with that letter is highlighted in the Artwork window. Great.
What I thought also might make sense (but might be hard to implement or not make sense for another reason) is that the Track Brower column I have displayed for Album-Artist should also jump to that letter choice.
Not a big deal of course. Just a suggestion that might make things a little better - and maybe more consistent?
Anti
The problem is that the track browser acts like a filter, whilst the a-z bar doesn't. Eg.
Clicking 'J' on the a-z bar takes me down to 'jimi hendrix' in the main pane, but the library is not filtered; I can still scroll from 'J' through my entire library. If, as you suggest, the track browser was synchronised and therefore highlighted 'jimi hendrix' in the album artist column, then because it is a filter, only the hendrix albums would/should be shown in the main panel.
Using the track browser filter, you're supposed to start off with a general filter on the left hand side, and get progressively more detailed moving toward the right.
The library explorer is also a filter, so again syncing the a-z bar with it would not work either.
Note that the track browser and library explorer *are* synchronised with each other.
