Hello,
1. Sorry for choosing the wrong place in the forum for the question and thanks to sveakul. During my initial search for the right location, I couldn't find a specific area for the portable version. Could someone please provide me with the link to where we should move (and so that I don't pick the wrong place to solve the problem again)?
2. If there are any problems with the move (when you receive one, here is the current status:
a. As far as I remember, I had seen the instructions you linked to a few days ago and did the same thing back then.
b. When I reinstalled again, I had already created a folder myself to keep everything clear (C (=System partition) - Protable Versions - MusicBee Portable), into which I chose the path for the installation. However, no content could be seen there after the installation (not even after I had protected and hidden files displayed).
c. I have now installed it again, consciously following Sveakul's instructions (without deinstalling beforehand, as this is not displayed in the app area of Windows (probably normal for portable versions))
d. Strangely enough, as I noticed, in the path to be chosen for the installation, a "MusicBee" folder is shown as being on the desktop and selectable, but it is not visible on the desktop itself.
e. Also strange: after the new "installation" (like the last one; but I used different target folders for both so that nothing can collide) no file, no folder and especially no MusivBee.exe file are displayed in the line folder , from which I could link to the start menu or somewhere else. This also applies here, even if I make hidden and protected files basically visible.
f. If it helps you gain some insight: The windows that are displayed for MusicBee Portable during installation and also the MusicBee program window that opens afterwards all have a green outer border (is this supposed to indicate that a program is running as a portable version?) . If the installation of MusicBee Portable were to work at all, I would like to have this green border removed (is this a setting that you can change in MusicBee Portable itself or in Windows and if so, where exactly?).
Hopefully it's not the case that I'm so incompetent, have such strange (security) settings or that the MB Portable is programmed so strangely that the installation problems described arise?
Ko
