Am having an issue where a certain track in my playlist ends slightly earlier than it should, cutting off the last bit of a song, probably less than a second's worth.
Previously had this with other tracks, but was fixed for most of them when I enabled the "load entire file into memory" option in preferences>player. This specific track was the only one that seems to have not been fixed.
Some more context worth noting is that based on my testing, the track only seems to cut off at the end when it's been shuffled into, when shuffle is disabled and it queues normally, it plays in its entirety as it should. Have also tested the track in foobar2000, where regardless of whether shuffle is enabled or not, it plays fine.
Any chance I'm missing a setting somewhere to fix this, or is this a bug?
