Author Topic: MusicBee app closes when album finishes using WASAPI Exclusive mode  (Read 409 times)
FusionFist
Been using the app for years but never noticed this behaviour before... On my machine playing an album or playlist or queued songs using WASAPI mode everything plays but when the last song of the list has finished MusicBee closes. Nothing is reported in the error log and this behaviour does not happen if I play in DirectSound mode. It took me a long while to go through the settings but it is certainly WASAPI causing this issue on my machine. Any ideas or can the issue be replicated, am not sure if this is a bug or some setting I am missing? Am using a portable install with the current latest version from patch update in forum v3.5.8447 on Ryzen 5900x system, Windows 11.
Not that I think it will help, but the latest patch is 3.5.8501 (or possibly later.)
Does the issue occur using WASPI Shared?
FusionFist
Thanks for the replies, to answer the above...
I've got a few plugins installed, I've tried disabling them, restarting and the issue persisted, it didn't seem to matter which ones were enabled or disabled to replicate the problem.
Also tried choosing different outputs, like SPDIF and Headphones but it still just occurs in WASAPI exclusive mode. Just checked WASAPI Shared mode and that works fine.
I can't see version 3.5.8501 publicly linked on forum, is it a beta/developer version?
Upon further testing I've downloaded a clean portable version alongside my portable version and cannot replicate the issue even after duplicating the settings so am having a look into it when I get some more free time and will report back if I find anything out...
You can get the latest 3.5 patch from my signature below.
