I'm in the process of re-ripping my CDs as FLAC and am stumbling a bit on the best path to manage removal of the MP3 tracks from MB db. My current workflow is:
Rip to Inbox
Send to Folder ->Move (organized)
Sometimes due to changes in tagging that occur with the new rips, I'll get two copies of the album in my MB db. If they get put in the same album then there are both the MP3 and the FLAC version in that album.
If two album copies occur, I can easily delete it from the computer node. It seems to delete the actual files from the windows file system as well.
If I get duplicates in the same album, I can use the computer node view, drill into the album, sort by ext and then delete.
Am I missing an easier way?
