Author Topic: Reverse syncing playlists  (Read 1759 times)
hesota2311
Hi!
I finally got around to using the wifi sync instead of plugging my phone everytime, and its been working perfectly. I did see however on the wifi sync app that you could reverse sync playlists, and I've been trying to figure out how to do it. Basically, I have my playlists from my PC synced to my phone right now, and I would like it if for example, I added a song to one of my playlists on my phone, and when I sync to my pc again, that version of the playlist gets updated with the song I added on the phone.
Just wondering if that's possible, would be to have the option to edit my playlists while outside. If not, that's fine! Still love this player a lot :)
Also if it helps, I use GoneMad as my music player on android
GoneMad and PowerAmp are the only two apps that can reverse sync via WiFi with MB. I use GoneMad, but I don't care about reverse syncing. I just looked at the MB's WiFi settings on my phone and under "Reverse Sync to computer" playlists is grayed out. But as soon as I tapped "GoneMad" in the "from player" section, playlists became available.
If you can't get GoneMad to work as you wish, I suggest trying Power Amp and see if that takes care of it.
