Author Topic: New User, Scan Freezes  (Read 879 times)
BCochrane
Downloaded MusicBee from web site, started scan on an external drive E, and scan froze.
Restarted program, could not get Scan to restart. Un-installed app, re-installed from Microsoft Store, but again Scan froze, on 5,236 of 21,187. Again, cannot get Scan to re-start.
Ran Disk Check via Glary Utilities, it reported no errors
Any suggestions?
Thanks
Sometimes a corrupted file can stop MusicBee from completing its scan.
Try adding your music in smaller batches to narrow down which one might be causing a problem.
(And in general, don't use the Windows Store version of MusicBee unless you need to - a portable or normal installation will be easier to manage and troubleshoot)
I have updated MB so that when a corrupted file freezes the scan process, MB will log that filename to the error log.
Let me know if you would like to try it
Last Edit: March 28, 2023, 09:00:55 AM by Steven
BCochrane
Yes, would like to try your fix. How do I access it?
The Incredible Boom Boom
The error log can be found in the ../MusicBee/AppData folder.
The OP is asking Steven how he can access the fix.
And the easiest way to find the error log is Help > Support > View Error Log
Uninstall the store version, then install the desktop version from the downloads page.
The download this file:
BCochrane
Did as suggested, but had the same problem. Then repeated the install process as suggested and ran Scan against a sub set of my library (different drive & Folder)
It too stopped, having scanned 5,141 of 9,689 items. That may not have been exactly the same number at which Scan stopped on the dull library, but it is quite close.
SO my first guess would be a capacity problem??
it wont solve the freezing - it should log the file it freezes in the error log (help/ support/ view error log)
what version does help/ about say?
BCochrane
Version is 3.5.8447
Last few entries in errorlog
2023-03-29 7:38:32 PM - File open failed: D:\Music\111 Years Of Deutsche Grammophon (55 CD)\54 - Wunderlich - Schumann - Dichterliebe\28 - Franz Schubert - Der Musensohn, D.764 (Op.92,1).flac,FLAC__METADATA_CHAIN_STATUS_NOT_A_FLAC_FILE
2023-03-29 7:38:32 PM - File open failed: D:\Music\111 Years Of Deutsche Grammophon (55 CD)\55 - Zimermann - Liszt - Concertos\01 - Piano Concerto No.1 in E flat, S.124 - 1. Allegro maestoso.flac,FLAC__METADATA_CHAIN_STATUS_NOT_A_FLAC_FILE
2023-03-29 7:38:32 PM - File open failed: D:\Music\111 Years Of Deutsche Grammophon (55 CD)\55 - Zimermann - Liszt - Concertos\04 - Piano Concerto No.2 in A, S.125 - 1. Adagio sostenuto assai - Allegro agitato assai.flac,FLAC__METADATA_CHAIN_STATUS_NOT_A_FLAC_FILE
2023-03-29 7:38:32 PM - File open failed: D:\Music\111 Years Of Deutsche Grammophon (55 CD)\55 - Zimermann - Liszt - Concertos\06 - Piano Concerto No.2 in A, S.125 - 3. Marziale un poco meno allegro.flac,FLAC__METADATA_CHAIN_STATUS_NOT_A_FLAC_FILE
2023-03-29 7:38:32 PM - File open failed: D:\Music\111 Years Of Deutsche Grammophon (55 CD)\55 - Zimermann - Liszt - Concertos\07 - Piano Concerto No.2 in A, S.125 - 4. Allegro animato - Stretto (molto accelerando).flac,FLAC__METADATA_CHAIN_STATUS_NOT_A_FLAC_FILE
2023-03-29 7:40:18 PM - File open failed: Found invalid data while decoding.
D:\Music\Alfred Brendel_ Neville Marriner_ Academ\The Mozart Experience, Vol. 2 - Piano Co\01 Mozart_ Piano Concerto #20 In D M.m4a
...it would appear - as posited earlier - several of your files are corrupted.
Try rescanning without the folders for the above files selected.
Version is 3.5.8447
please carefully re-read and apply the installation instructions i gave you
Last Edit: March 30, 2023, 09:33:22 PM by Steven
