Author Topic: Help with Template ?  (Read 606 times)
crnirg
If you can help:
I have a song :
Eric Clapton Backless - 04. Roll It
where is "Eric Clapton" Artist and "Beckless" is Album, the rest is self-explanatory, how can I make a template so that the first two words indicate Artist and the third the album?
You know what the fellow said – in Italy, for thirty years under the Borgias, they had warfare, terror, murder and bloodshed, but they produced Michelangelo, Leonardo da Vinci and the Renaissance. In Switzerland, they had brotherly love, they had five hundred years of democracy and peace – and what did that produce? The cuckoo clock.
Seriously? You can't figure out
<Artist> <Album>
crnirg
I get
Eric - Artist
and
Album - Clapton Backless ...
Then your tags are not correct.
A screenshot of the tag editor with this album might be helpful here.
And where are you seeing the result you say you're getting?
crnirg
I have a file
Eric Clapton Backless - 04. Roll It.mp3
and I want to do the tags as I said
Normally it's not 1 song but more so it's not really for manual editing.
The problem is how to put the first two words in Artist and the third in Album.
I guess I explained better what's bothering me :)
Ok, I -think- I now know what you're trying to do.
You have a file that has the filename Eric Clapton Backless - 04. Roll It.mp3 and you want to bring the file into MB, is that correct? But it appears in MB as
Eric - Artist
and
How are you getting it into MB and I'll ask again, where are you seeing it incorrectly? A screenshot might help.
crnirg
Maybe my speed is causing confusion - I permuted the result:
This is the result:
Artist = Eric
Album = Clapton Backless
Track# = 04
Title = Roll It
I would like it to be:
Artist = Eric Clapton
Album = Backless
Track# = 04
Title = Roll It
When you mentioned the file that is on my old CD
I want to switch to HD and then arrange the tags in the described way.
The problem is that I don't know how to combine 2 strings into one (Eric+Clapton) because I don't have a character to separate ( - , . or similar).
If you're not kidding me, I think I've explained my pain well :)
Since you've repeatedly ignored my request for a screenshot, and ignored my various questions, I won't be able to help any further.
MotleyG
This is the result:
Artist = Eric
Track# = 04
Title = Roll It
Album = Backless
Track# = 04
Title = Roll It
Without a defined separator, this is pretty complicated to automate. There are so many possible patterns that could exist with a large batch of files. What if the Artist has just one name, like Cher? Or three or more names like Creedence Clearwater Revival? It gets further complicated by punctuation like Earth, Wind & Fire. So while it may seem like a quick fix, you could end up causing a whole lot of worse issues to fix instead.
How many songs are you trying to fix like this? It may be more efficient to simply do one album at a time.
crnirg
I don't know how :
https://gifyu.com/image/SIv2f
or :
or : https://s2.gifyu.com/images/imaged83cec448a98ad33.png
where is:
Album = Dedić Na obali
Artist = Arsen
it should :
Album = Na obali
Artist = Arsen Dedić
The Incredible Boom Boom
It's probably easier to use MusicBrainz Picard to fix your tag information. If you would rather do it manually, the next easiest option is mp3tag, which - if your filenames have the same format - you can possibly use to guess a file's tags based on its filename.
crnirg
Thanks for the answers - there are a lot of them - about 650 - when ripping from the original CDs, an error crept in that I wanted to fix now - in any case, thanks for the answers.
You won't be able to parse the tags correctly until you fix your file names.
I'd suggest downloading one of the many free batch file renaming programs and replacing "Eric Clapton" with "Eric Clapton - " or whatever the artist name is.
Then you can use the hyphen in your tag template.
crnirg
The files are not uniform - I thought it was possible to do something like word1 + word2 = word3 and then separate them and insert them into tags.
Thank you for the answers.
crnirg
My solution for 2 words Artist :
Virtual Tag1 -->> $Split(<filename>," ",1) $Split(<filename>," ",2)
and Swap
<Virtual Tag1> to <Artist>
