After running "Rescan All Files" (at about 20,000 records scanned) or "Scan Folders for new files" (at about 10,000 records scanned) I get the following errors:
MusicBee v3.5.8447.35843Store (Win10.0), 15 Mar 2023 20:25:
System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
at System.Runtime.InteropServices.Marshal.GetFunctionPointerForDelegateInternal(Delegate d)
at System.Runtime.InteropServices.Marshal.GetFunctionPointerForDelegate(Delegate d)
at System.Windows.Forms.UnsafeNativeMethods.SetWindowLongPtr32(HandleRef hWnd, Int32 nIndex, WndProc wndproc)
at System.Windows.Forms.UnsafeNativeMethods.SetWindowLong(HandleRef hWnd, Int32 nIndex, WndProc wndproc)
at System.Windows.Forms.NativeWindow.AssignHandle(IntPtr handle, Boolean assignUniqueID)
at System.Windows.Forms.NativeWindow.AssignHandle(IntPtr handle)
at System.Windows.Forms.NativeWindow.WindowClass.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Also, I found a few hundred files corrupted. Not sure when these happened, if they are related, or if this is a separate issue.
