Author Topic: rewind buttons?  (Read 247 times)
qwerty29
hi , I'm aware of the rewind hotkeys but I was wondering if it is possible to add rewind buttons in the player controls?
you can add command buttons to the header bar
You can also use hotkeys, but toolbar commands could look like this
qwerty29
thank you for your answer :) , it works nicely but not in miniplayer , is there a way to show the toolbar in the miniplayer? or can I customize the player controls bar instead?
I also tried using hotkeys while using the miniplayer but it didn't work because I was using other apps at the same time (and it was in the background) , I had to click on musicbee miniplayer first and then use the hotkeys
Last Edit: March 18, 2023, 01:29:19 PM by qwerty29
qwerty29
