Author Topic: MusicBee 3.5 - issues with with keyboard press jump by Song Title  (Read 395 times)
belomeclone
In MusicBee 3.5, when I try to jump to songs with keyboard presses, it just doesn't work. It usually ends up jumping to the same song. I can get it to almost work by pressing one of the letters at the top, but that eventually breaks. I can press every letter and they just end up greying out. "Enable multi-character searches" is on.
I don't understand what's going on. Doing this sorting by Artist, or Album has no problem. I can't use this if it's not going to work. It works fine in 3.4.
belomeclone
It would just be a screenshot of my entire MusicBee screen. They all jump to "The Cosmic Gate" by Thievery Corporation. I can type "J", it jumps to that. I click to reset and type in "x", it jumps to an X song, then I press X again and... it jumps to a Y song. Now I type "J" and it keeps jumping to that X song. It doesn't make any sense.
I clicked to reset and typed in "S", and it jumped to "The Cosmic Gate" again. It's just this over and over. If I go to 3.4 and type in letters, it jumps to the letters I type in.
I took a small snip of the letters at the top so you can see them depressed without doing anything. It's possible I messed something up when copying files over, but it just shows the need for a smoother upgrade process.
https://i.imgur.com/HWna8JH.png
are you using the v3.5 from the downloads page and not an older beta?
belomeclone
I am using 3.5 from the downloads page, and the patch.
I re-copied over the Library folder from 3.4 to 3.5 and it seems to have fixed the issue. I know we have no control over things, but if MusicBee could update itself I think it'd be a large boon to the update process. I seemed to have a lot of struggles with the update process. Or maybe like some older portable systems worked, Library can go inside AppData, so when you download a new install you only copy over one folder. Library shouldn't be separate if it also has AppData. Same for Skins and Plugins really.
I am already running the patched version.
Steven uploaded that patch today. If you haven't downloaded and installed it today, then you're not running it.
The Incredible Boom Boom
This might be a sorting issue.
In the Sorting/Grouping menu in Preferences, do you have "enable custom sort values" enabled?
belomeclone
Is there a reason they're patches and not a new version number? I find it hard to tell what version I am on if there are patches for versions, and not a continued increase in version numbers. Or if they are an increase in version numbers, why are they called patches?
I downloaded the patch and things are still running fine. I think it was an issue with the Library file.
