Author Topic: Problem with $if(<field>=<field>...  (Read 552 times)
Johan_A_M
I'm having a strange problem with the $if(<field>=<field>,true-value, false-value) function. I'm trying to create a template that adds some information if <year> is different from <original year> (basically add country and mastering). However, I can't get it to work, as can be seen in the screenshot.
Here are the information in Tag Inspector:
Isn't it strange that the equal sign and less than sign give the results they do?
vincent kars
A possible explanation can by the type.
The documentation says that < and > only works on numerical tags.
Year and OriginaL Year might by of the type "date"
MB isnt handling 4 digit years as a date
This should fix the issue:
Johan_A_M
Thank you Steven, that fixed it!
And thanks Vincent for trying to help!
