Author Topic: Is there a way to change the size of the highlight icons?  (Read 481 times)
Brendan Stupik
Hello, long time MusicBee user here with a quick question: is it possible to change the size of these highlight icons? https://snipboard.io/ZCoUhK.jpg  I only use them on albums, and I'd like to make them larger than they are. If anyone has any idea how to do this, I'd appreciate any help! Thanks :)
My understanding is that they're hard-coded and can't be changed.
They might stand out more if you used a color instead of an icon, not that it will be any larger.
