I did an in-place update from W7 to W10. All seemed to be fine until I had an podcast update. I investigated the error log and noticed this:
20-2-2023 08:28:19 - refresh subscriptions failed:Access is denied. Ensure that your windows account has permissions to write to the directory and file.
C:\Program Files (x86)\MusicBee\Library\Muziek\Podcasts\Subscriptions.dat
20-2-2023 08:28:25 - download failed: url=https://mp3s.nashownotes.com/NA-1531-2023-02-19-Final.mp3,ex=Access is denied. Ensure that your windows account has permissions to write to the directory and file.
20-2-2023 08:28:27 - download failed: url=https://mp3s.nashownotes.com/PC20-122-2023-02-17-Final.mp3,ex=Access is denied. Ensure that your windows account has permissions to write to the directory and file.
20-2-2023 08:42:48 - 10.0.19045.0 - 3.5.8447.35892D - System.UnauthorizedAccessException: Access is denied. Ensure that your windows account has permissions to write to the directory and file.
C:\Program Files (x86)\MusicBee\Library\Muziek\MusicBeeLibrarySettings.ini
at #=zCJ5ZbFh4yYYfdpqpAoCXcqc=.#=zTOu0g1i0yHIW.#=zWeOFwjY=.#=z6KaNcWVRUyQf(#=z4$90odPQW5oVh9588w== #=znXOuPj4=, FileMode #=zTky_wYc=, FileAccess #=zv2o$ssw=, FileShare #=zcz1ygUg=, Int32 #=ziMmzlMk=, Boolean #=zveLPR8JQqcIP)
at #=z9Ul3ZTFHMA9L523_nn5Km4w=..ctor(#=z4$90odPQW5oVh9588w== #=znXOuPj4=)
at #=zPvI1Uy1iDbZdVUmqNyClZIw=.#=zk2ZoDzk=.#=z2LpFPNI=()
C:\Program Files (x86)\MusicBee\Library\Muziek\MusicBeeLibrary.bak
at #=zCJ5ZbFh4yYYfdpqpAoCXcqc=.#=zTOu0g1i0yHIW.#=zWeOFwjY=.#=zIO5SeK0=(#=z4$90odPQW5oVh9588w== #=zuPi1nLmHEbJ$, #=z4$90odPQW5oVh9588w== #=zo5NuiHPeASa6, Boolean #=zveLPR8JQqcIP)
at #=zgOJ1TEbjxTQ8lNm9Tf0qUe4=.#=ze0E8GlwfYc1O.#=zDq7AngtamK6E(Boolean #=zcfWBfgxtq6gkyCzPOQ==)
at #=zgOJ1TEbjxTQ8lNm9Tf0qUe4=.#=ze0E8GlwfYc1O.#=zd4VZ5HMm9llf()
at #=zPvI1Uy1iDbZdVUmqNyClZIw=.#=zSzXOBJ0$TviR()
at #=zn853qfMp_Exq7p88o7Zl0V_k5Mz4.#=zdmzdJdw=.#=zQghzHFI=(CloseReason #=zsG8QKU4=)
I checked permissions, which seemed fine on my music disc, nothing changed in that regard. The episodes also downloaded and worked, but every time i started MB, they downloaded again, with the error. The MBL database file didn't save either after start-up/shutdown like it normally does.
The problem seemed to be writing rights for MB itself in regard to C:\Program Files (x86)\, although my windows account is an administrator account. So I changed the MB link itself, to run as an administrator and that worked. No more errors.
- My questions(s) is (are) is that normal to do so in order to run MB under W10?
- Do i need to change anything?
- Do i need to install MB in C:\Program Files\ instead of C:\Program Files (x86)\?
MB is the normal windows version 3.5.8447.35892D
Thanks.
