Author Topic: Track Rating  (Read 485 times)
KeithA
I have just moved to MusicBee.  It seems great however I just ran into an issue.  I had previously applied ratings to some of my songs but when they are viewed in MB they parent showing.  I have noticed that MB lists a 5 star rating in the tag as 200.  However,  the previous software lists it as 10.  Is there any setting tweak to make them align?
Thanks
  • Heal The World
In MusicBee, what figure do you see for the <rating> tag in the Tag Inspector? (which you can open from a right-click > edit) Is that the 200?
And also, when you display the <rating> tag in your main panel, what figure do you see there for such a track? (should be a digit between 0 and 5, I believe)
If you can establish a pattern between the actual rating from your previous player and the figures that MusicBee is showing in its <rating> field,
then you can easily filter your library accordingly and re-rate your files in batch (in other words, updating them to rating figures that MusicBee recognizes)
Strength and Honour (2025)
