Author Topic: Button to open a file explorer window in the location of selected song(s)  (Read 847 times)
Mr.man1093
It would be nice to have a button on the metadata editing window that would open the currently selected file(s) root folder in file explorer. The image below shows an example of the area where this button would appear in the editing window outlined in red.
https://i.imgur.com/m7VPng0.png
voodoopunk
Just point out and I'm sure you know, but you can use right-click > search > Locate in Windows Explorer before/after you edit the file(s). I'm not sure what purpose it would serve to do it while editing.
You can make a button on the toolbar that will do this easy if that is an OK substitute:
