Author Topic: Unable to install Advanced Search & Replace plugin presets  (Read 583 times)
Thornogson
I have installed the Additional Tagging & Reporting Tools Plugin which seems to work fine - apart from one issue -  the Advanced Search & Replace presets will not install. Although they show up after I click 'Install New' - I immediately get the following error and I am unable to save them:
MusicBee v3.4.8033.18564D  (Win10.0), 4 Feb 2023 15:23:
System.ArgumentException: Illegal characters in path.
   at System.Security.Permissions.FileIOPermission.EmulateFileIOPermissionChecks(String fullPath)
   at System.IO.Directory.InternalCreateDirectoryHelper(String path, Boolean checkHost)
   at System.IO.Directory.CreateDirectory(String path)
   at MusicBeePlugin.AdvancedSearchAndReplaceCommand.install(Boolean installAll)
   at MusicBeePlugin.AdvancedSearchAndReplaceCommand.buttonImportAll_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
Can anyone provide a solution?
Many thanks
Try updating to the latest MB version (3.5.x) from the first forum topic.
Glad to hear that's all it needed.
