Author Topic: List of auto generated music urls.  (Read 17138 times)
right now the only way would you for you to open your own window (see boroda74's Advanced Plugins API as an example - you can see the source code for it)
There isnt any API support for adding panels directly to MB - i would be prepared to add that but not right now
e-motiv
(EDITED twice)
Thanks.
I've been browsing his source for a while,  and finally found it, but it's too hard for me to implement anything in it (will cost too much time).
I will stick to the Menu Items for now.
For people possibly looking for the same, this is how to make a window (for now) (check boroda74 for skinning) :
mbForm = (Form)Form.FromHandle(mbApi.MB_GetWindowHandle());
ownedForm.Text = "Radio Dig";
mbForm.AddOwnedForm(ownedForm);
ownedForm.Show();
Steven,
1. Any ideas about my previous post, about refreshing / loading new plugins  without closing MB?
2. Also, I would love it if API could make a new Dropdown  in Navigator Panel.   :P
3. And tertio, NowPlayingList_QueueNext does not work if the character '-' is inside the string. Does it have to be URL-encoded or bug?
EDIT: HttpUtility.UrlEncode does not encode "-" (dash)! So, maybe "dash" should be allowed and it's a bug after all?
Now it works with dash!!!???  Maybe Steven fixed it in a weekly build. Thanks if so!
Last Edit: November 08, 2011, 02:56:44 PM by R U Bn ?
  Developing @ e-motiv.net       --       Musicbee plugins: Speak Back - Ghost Tracks - Radio Dig
