Author Topic: `Replace the Selected File` feature should copy existing lyrics into new file  (Read 695 times)
ryco117
I use MusicBee to manage the lyrics of my songs. However, when using the `Replace the Selected File...` menu options the lyrics of the existing file are not copied into the newly imported file.
Since other tags from the managed file are already copied into the new file when using this process, I think it is slightly unintuitive that this occurs; it also makes the process of using the `Replace the Selected File...` feature slightly slower.
I'd appreciate consideration of this change.
Thanks,
Ryan
