Author Topic: Support for HUD Lyrics  (Read 3194 times)
greenday1987
  • Long live OiNK!
http://factormystic.net/projects/gadgets/hud-lyrics
Not sure if this can be done from a MB end with a plugin or can only be added by the HUD devs but thought I'd shoot it in here anyway
RIP OiNK
greenday1987
  • Long live OiNK!
That's an idea although I think currently CAD is not supported. Gonna try this one though :)
RIP OiNK
Greb
CAD version 3 is supported (but not previous ones. Specifically, version 2 it's not supported). Indeed it's supported by the MusicBee release directly (I use it). It's a bit messy, since you have to start CAD, and after that to close MusicBee and to open it again so it connects... but it works without problems. Check it.
To enable it, go to Preferences > Plugins.
Last Edit: June 30, 2011, 11:57:20 PM by Greb
