I could create ASR preset to copy any tag to guest artists.
http://www.mediafire.com/download/s87uco67sc2l5i7/mb_TagTools_2014-04-04.zipSee new ASR preset 'Copy guest artists from <Tag 1>'
- There's a typo in the preset name- How about using MB default delimiter "; " instead of ","?
- Can you show in the dialog just guest artist tag values? Currently it shows them along with artist values that could be confusing.
Could you also create a new preset that removes all duplicate entries from a multi-value field like genre and artist? That'd be useful for various cases including the request in this thread: http://getmusicbee.com/forum/index.php?topic=12441.0Would be great if the preset could remove multiple kinds of duplicate entries at once regardless of their places (consecutive or not).
See ASR preset 'Remove duplicated entries from <Tag 1>'http://www.mediafire.com/download/88pjrri86eyto6r/mb_TagTools_2014-04-04-2.zip
It works, but with some limitations.- For genre tag, it removes one duplicate entry at a time. So for the given string "Funk; Funk; Funk; Pop; Pop", it needs to be applied 4 times to make it "Funk; Pop".
- For some reason, artist tag doesn't show a semicolon between multiple artists on the plugin dialog. Because of this, I can't make the preset work for artist field.
