Author Topic: Additional Tagging & Reporting Tools  (Read 937406 times)
Regarding multiple tag editing, are there any differences between the two 2-22-2 dll files? They look just the same in their file size and modified date.
No, they are the same. I just reposted the link .
Yet, previous version is working without issue (except refreshing the changed tag value) while current version sometimes does not work properly: file gets missing, auto-applied preset fails rewriting tags, etc.
Could you be more specific?
Moss
by every start from MusicBee I got this error message.
Can you tell me whats wrong. What can I do?
Moss
Last Edit: February 27, 2014, 05:28:17 AM by Moss
Moss
Adding Titel / TrackTitle
Adding Album / Album
Adding Album-Künstler (displayed) / AlbumArtist
Adding Album-Künstler / AlbumArtistRaw
Adding Künstler (displayed) / -1
Adding Künstler / -2
Adding Cover / Artwork
Adding BPM / BeatsPerMin
Adding Komponist (displayed) / -3
Adding Komponist / -4
Adding Kommentar / Comment
Adding Dirigent / Conductor
Adding Disk-Nr. / DiscNo
Adding Disk-Anzahl / DiscCount
Adding Encoder / Encoder
Adding Genre / Genre
Adding Genrekategorie / GenreCategory
Adding Gruppierung / Grouping
Adding Schlüsselwörter / Keywords
Adding Texter / Lyricist
Adding Stimmung / Mood
Adding Anlass / Occasion
Adding Herkunft / Origin
Adding Verlag / Publisher
Adding Qualität / Quality
Adding Bewertung / Rating
Adding Album-Bewertung / RatingAlbum
Adding Lieben / RatingLove
Adding Tempo / Tempo
Adding Titelnr. / TrackNo
Adding Titel-Anzahl / TrackCount
Adding Jahr / Year
Adding Liedtext? / HasLyrics
Adding Virtual1 / Virtual1
Adding Virtual2 / Virtual2
Adding Virtual3 / Virtual3
Adding Virtual4 / Virtual4
Adding Virtual5 / Virtual5
Adding Virtual6 / Virtual6
Adding Virtual7 / Virtual7
Adding Virtual8 / Virtual8
Adding Virtual9 / Virtual9
Adding Virtual10 / Virtual10
Adding Virtual11 / Virtual11
Adding Virtual12 / Virtual12
Adding Virtual13 / Virtual13
Adding Virtual14 / Virtual14
Adding Virtual15 / Virtual15
Adding Virtual16 / Virtual16
Adding Liedtext / -5
Adding Liedtext (synchronized) / -6
Adding Liedtext (unsynchronized) / -7
Adding <Null> / -20
Adding Sort Artist / Custom1
Adding Sort Album Artist / Custom2
Adding Custom3 / Custom3
Adding Custom4 / Custom4
Adding Custom5 / Custom5
Adding Custom6 / Custom6
Adding Custom7 / Custom7
Adding Custom8 / Custom8
Adding Custom9 / Custom9
Adding Custom10 / Custom10
Adding Custom11 / Custom11
Adding Custom12 / Custom12
Adding Custom13 / Custom13
Adding Custom14 / Custom14
Adding Custom15 / Custom15
Adding Custom16 / Custom16
Adding Genres / Genres
Adding Künstler / Artists
Cant add Künstler / Artists
Adding Künstler: Künstler / ArtistsWithArtistRole
Adding Künstler: Performer / ArtistsWithPerformerRole
Adding Künstler: Gast / ArtistsWithGuestRole
Adding Künstler: Remixer / ArtistsWithRemixerRole
Its strange that German translation of 'Artist' and 'Artists' tags are the same for your MB (tag names are duplicated). Go to Edit> Prefs> Layout (1)> Configure fields and rename Artists field from 'Künstler' to German multiple form of word or to something else other than 'Künstler'.
Last Edit: February 26, 2014, 04:16:09 AM by boroda74
New plugin version released
  • New <Date created> pseudo-tag (track file creation date) is added to ASR command.
http://musicbee.wikia.com/wiki/Additional_Tagging_and_Reporting_Tools
  • New option 'Show commands in context menu'. Go to plugin prefs to check it.
  • Minor bugfixes.
Working great! This saved me two hotkeys, which I can now assign to other commands.
Do you mean 'Show commands in context menu' option? Thanks to Steven :)
Came from here: http://getmusicbee.com/forum/index.php?topic=12221.0
There's a problem writing MB's 5 point scale rating values (when sent to clipboard with <rating> in Tags(2) setting) back to files. Tried with both clipboard and text file options, but "No rating" does not overwrite the file's existing rating value. Preview shows correctly, though.
BTW when I tried to run copy command with text file option without choosing a text file, it gave me a long error message. Maybe it could just return focus to the text file selection box instead since it's most likely the user simply overlooked to do so.
Can't reproduce what you said, but there was a bug with ratings. Ratings in text file/clipboard must be in 0-5 range.
I've added simple error message "File not found!" if source files doesn't exist or file name is empty.
http://www.mediafire.com/download/3dc1c74725ss85f/mb_TagTools_2014-03-08.zip
The bug wasn't fixed. It's working fine with all other ratings including bomb. It doesn't work properly only when overwriting an existing value with "No Rating". It doesn't clear it, and the file keeps the old rating value. You can't reproduce this?
Working fine for me overwriting bomb, empty or any other rating. I don't understand how initial value of rating might affect 'copy tag' command behavior if you don't tick "Append source tag to the end of destination tag placing between them:" or "Add source tag to the beginning of destination tag placing between them:" options.
