Author Topic: Additional Tagging & Reporting Tools  (Read 1170128 times)
Here's my suggestions using a virtual tag.
1. Copy and paste the following to label and formula box under Tags(1)> Define New Tags
FeatArtist=$Split($Split(<Title>,"(ft.",2),")",1)
Add the column to main panel and sort by it.
Select all the tracks that have a value in the field.
2. Go to Tools> Tagging Tools> Copy tag
Source: FeatArtist Target: Artist
Tick "smart copy" and "append source tag..." and put ";" in the box
Preview and Proceed.
3. Select all those tracks, open ASR preset pane, find "Generate Display Artist..." and run it.
WimYogya
@redwing:
Sounds like a good suggestion although I am not expert enough to understand it. But if I would need the same I would sure test it! ;-)
@ajfudge:
In general: MB itself plus the excellent ASR plugin options make almost every manipulation possible, is my experience after 1 month.
The question often remains: is it worth the lot of work that you have to do before you have everything exactly uniformised in your desired format.
I am struggling with that question myself too.
Options are endless, time and energy are not...
Success!
WimYogya
retired Dutchman (1944) in Yogyakarta, Indonesia
WimYogya
As I noticed before: sometimes (with some presets?) ASR seems to skip certain or all fields.
As far as I can analyze it now, it is just a matter of refreshing: after a restart the values have been added to the respective fields.
I experienced it a few times today with the 'add zeros to track number' presets: after applying the preset to 15 tracks of 1 cd nothing changed.
Repeating the application didn't make a change.
The restart did: the 01, 02 etc were there...
Later the same happened when I wanted to combine two fields and append an opera title to the beginning of the title field.
No changes visible until after a restart.
Please check the refreshing issue.
Last Edit: March 02, 2013, 10:47:47 AM by WimYogya
WimYogya
What's happened if you hit F5 button? Are fields refreshed?
WimYogya
Seems ok after hitting F5.
Still, autorefresh would be nicer (and is sometimes automatically done)
Could you let it ALWAYS happen? ;-)
WimYogya
Then it's a bug in plugin. I'll check auto-refreshing in it. Last question: Fields aren't updated when preset is auto or manually applied?
WimYogya
I dont use autoreply (yet) coz it (still) slows down my performance.
So my experience only comes from manual application.
WimYogya
superstar19
I keep getting this error (just downloaded the latest beta):
Some tag names are duplicated. Plugin is not properly initialized.
I'm using MB 2.1.4770 and the latest plugin (also tried the 2013-03-02 version), and get the same message.   Is there something else I'm missing?  I've loaded the files to the Plugins folder, but I still get this error.  I'm running MB on a desktop running Windows XP.
Last Edit: March 05, 2013, 12:37:19 AM by superstar19
WimYogya
Did you change any field names/labels? Check if some of them are duplicates. I had that before.
WimYogya
WimYogya
@Boroda:
Newest version solves most of the autorefresh problems. The rest is - as I think - part of an existing problem on my PC where autorefresh is sometimes not perfect. Thanks.
WimYogya
What localization of MB are you using?
superstar19
I'm just using the standard install (english?) without any localisation added.
