Hi Boroda,
I installed V10.0 Beta 3 and tried to make a Library report.
I selected some files and tried ALBUMS & TRACKS.
When I click Preview, either MB crashes completely or crashes and the At&RT windows remains open but cannot be closed.
Taskmanager doesn't show any MB application running but still I cannot start MB again.
I had to restart the PC to be able to launch MB.
Here are some errors logs:
25/06/2025 18:31:18 - 10.0.26100.0 - 3.6.9202.37404D - System.ArgumentException: Ongeldige parameter.
bij System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
bij System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
bij System.Windows.Forms.Control.Invoke(Delegate method)
bij MusicBeePlugin.Plugin.CopyBitmap(Bitmap newBitmap) in D:\Repos\Additional-Tagging-Tools\Plugin\Main-Module.cs:regel 6408
bij MusicBeePlugin.LibraryReports.ResizedArtworkProvider.Init(Int32 artworkField, SortedDictionary`2 artworkCache, Int32 presetNewArtworkSize) in D:\Repos\Additional-Tagging-Tools\Plugin\LibraryReports.cs:regel 2382
bij MusicBeePlugin.LibraryReports.executePreset(String[] queriedFiles, Boolean interactive, Boolean saveResultsToTags, String functionId, Boolean filterResults, Boolean forceCacheUpdate, SortedDictionary`2[] queriedGroupingTagsRaw, SortedDictionary`2[] queriedActualGroupingTags, SortedDictionary`2[] queriedActualGroupingTagsRaw, Nullable`1 readOtherwiseProcessExcludedGroupingTags) in D:\Repos\Additional-Tagging-Tools\Plugin\LibraryReports.cs:regel 2899
bij MusicBeePlugin.LibraryReports.previewReport() in D:\Repos\Additional-Tagging-Tools\Plugin\LibraryReports.cs:regel 5671
bij MusicBeePlugin.PluginWindowTemplate.serializedOperation() in D:\Repos\Additional-Tagging-Tools\Helpers\PluginWindowTemplate.cs:regel 4302
bij System.Threading.ThreadHelper.ThreadStart_Context(Object state)
bij System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
bij System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
bij System.Threading.ThreadHelper.ThreadStart()
25/06/2025 18:32:09 - 10.0.26100.0 - 3.6.9202.37404D - System.NullReferenceException: De objectverwijzing is niet op een exemplaar van een object ingesteld.
bij MusicBeePlugin.LibraryReports.prepareBackgroundPreview() in D:\Repos\Additional-Tagging-Tools\Plugin\LibraryReports.cs:regel 5612
bij MusicBeePlugin.PluginWindowTemplate.clickOnPreviewButton(PrepareOperation prepareOperation, ThreadStart operation, Button previewButton, Button okButton, Button closeButton, Boolean clearPreview) in D:\Repos\Additional-Tagging-Tools\Helpers\PluginWindowTemplate.cs:regel 4682
bij MusicBeePlugin.LibraryReports.buttonPreview_Click(Object sender, EventArgs e) in D:\Repos\Additional-Tagging-Tools\Plugin\LibraryReports.cs:regel 6847
bij System.Windows.Forms.Control.OnClick(EventArgs e)
bij System.Windows.Forms.Button.OnClick(EventArgs e)
bij System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
bij System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
bij System.Windows.Forms.Control.WndProc(Message& m)
bij System.Windows.Forms.ButtonBase.WndProc(Message& m)
bij System.Windows.Forms.Button.WndProc(Message& m)
bij System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bij System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bij System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
25/06/2025 18:32:20 - 10.0.26100.0 - 3.6.9202.37404D - System.NullReferenceException: De objectverwijzing is niet op een exemplaar van een object ingesteld.
bij MusicBeePlugin.LibraryReports.presetList_SelectedIndexChanged(Object sender, EventArgs e) in D:\Repos\Additional-Tagging-Tools\Plugin\LibraryReports.cs:regel 7507
bij System.EventHandler.Invoke(Object sender, EventArgs e)
bij System.Windows.Forms.ListBox.OnSelectedIndexChanged(EventArgs e)
bij System.Windows.Forms.CheckedListBox.OnSelectedIndexChanged(EventArgs e)
bij System.Windows.Forms.ListBox.WmReflectCommand(Message& m)
bij System.Windows.Forms.CheckedListBox.WmReflectCommand(Message& m)
bij System.Windows.Forms.ListBox.WndProc(Message& m)
bij System.Windows.Forms.CheckedListBox.WndProc(Message& m)
bij MusicBeePlugin.CustomCheckedListBox.WndProc(Message& m) in D:\Repos\Additional-Tagging-Tools\Helpers\CustomControls.cs:regel 2756
25/06/2025 18:33:32 - 10.0.26100.0 - 3.6.9202.37404D - System.NullReferenceException: De objectverwijzing is niet op een exemplaar van een object ingesteld.
