Author Topic: Additional Tagging & Reporting Tools  (Read 1208440 times)
Just wondering:
$SentenceCase(<Title>)
will work without any additional parameters
$TitleCase(<Title>)
doesn't work without additional parameters
hmm. indeed. i don't think it's MB bug. i'll check my code.
Just wondering:
$TitleCase(<Title>)
as usual, i haven't tested what i did. fixed version:
thanks for bug report.
Dizza17
@ Boroda,
Just a little shout out for your absolute dedication to consistently improving your plug in and going out of your way to accommodate the requests of the MB community. You’re definitely up there with the best of the best people who along side Steven, continue to make Musicbee a joy to use.
Cheers Aaron
When the rich wage war, it’s the poor who suffer.
After some further testing I have a suggestion and a question:
1.
word_separators
if you do:
$TitleCase(<Title>," the "," nyc "," : ")
on the title:
test the title: the nyc song
expected:
Test the Title: The NYC Song
result:
Test the Title: the NYC Song
I think 'word_separators' should overrule'lower_case_words'?
2.
lower_case_after_chars
quote: "consists of a list of characters, after which the words become lowercase (e.g., ' for something like "Someone's")"
I don't understand how or when to use this one.
If you do:
$TitleCase(<Title>," the "," nyc "," : ",','," ' ")
on the title:
hey c'mon, let's test someone's title
It will give the same result (Hey C'mon, Let's Test Someone's Title) either with or without that parameter?
Last Edit: July 26, 2024, 05:09:16 PM by hiccup
thanks. it's my hobby. everybody has some hobby  ;)
word_separators
if you do:
on the title:
expected:
result:
firstly, it's a major bug just because the first word must be capitalized always. secondly, probably you are right about overrule, but i need to check this. what rule do you think should take precedence?
If you do:
on the title:
i don't understand either  ;D it's just the option of dedicated "change case" command (which is used as backend for VT functions), which is useless in this case. i'll remove it. i think i'll keep it. maybe there are other useful use cases.
Last Edit: July 26, 2024, 07:58:44 PM by boroda
word_separators
if you do:
on the title:
expected:
result:
i can't reproduce this. i get:
The NYC Song
but:
Nyc the Song
i consider the second case a bug. i would expect in this case:
NYC the Song
i'll correct this.
Last Edit: July 27, 2024, 12:18:13 AM by boroda
The NYC Song
but:
Nyc the Song
i consider the second case a bug. i would expect in case:
NYC the Song
i'll correct this.
I can't do testing now, but perhaps you misunderstood the full title that I used as an example?
It's the whole:
It's the whole:
ahh! yes, i did. i'll re-test VT function.
meanwhile:
numerous though minor "change case" command and related VT functions fixes. "NYC the Song" case is fixed too.
Dizza17
Hi Boroda,
After some testing it appears the “sort involved people by their role preset isn’t working as expected. No changes are generated. Is there a small change to the pre-filled details that might need to be changed?
Regards Aaron
word_separators
if you do:
on the title:
expected:
result:
why would you expect "Test the Title: The NYC Song"? word separators are just word separators. they are only custom addition to spaces. and it's senseless in this case because there is an already space after the colon. what i can do is add new parameter "override all exception after chars". or change the meaning of the existing last parameter (which seems useless anyway) to this.
Hi Boroda,
Regards Aaron
i've just changed "sort performers" preset to sort all "artists" (not only performers). and i don't remember what "sort performers" preset does. it would be better if you just set me a task from scratch.
Dizza17
“Sort performers” sorts the artist tag list of performers by their instrument as written in the custom text box.
What i am after is to be able to sort the involved people tag by their role as written in the custom text box. Not just by alphabetical order of the role name but by any order as depicted in the custom text box. Ie: Engineer; producer; writer; lyricist; arranger; mixer.
Cheers
@hiccup, i've changed the meaning of the last parameter of $TitleCase function to something like "override all exceptions after chars besides the words from uppercase list". i even don't fully understand how exactly it works. too complicated code. but $TitleCase(<Title>," the "," nyc ",`,`,`," : ") converts:
to:
p.s. the words from the uppercase list must become uppercase always, without any exceptions.
@Dizza17, ok, i've checked the code, it seems good. could you give me an example of roles and artists tag, so i can check what is happening in debugger?
