new beta seems to be stable, but it would be great if somebody else has tested it. all changes relate to 5 things:
1. "copy tags to clipboard" window is now used not only for copying tags to clipboard, but also to simply select tags from some other commands (ASR, tag history, compare tracks). this window will look slightly different depending on context.
2. ASR support for <ALL TAGS> pseudo-tag is completed. preset support for this pseudo-tag must be enabled in preset editor 1st, i.e. this support can be added either to new user presets, or to user copies of predefined presets. either all tags, or only specified tags, or all tags except for the list of preserved tags will be processed, when using <ALL TAGS>.
3. now, LR presets can use another LR preset as the source of track list. of course, this makes sense only if the source preset uses conditional filtering (option "export/save tags only if..."). report itself generated by source preset is not used in this case, only filtered track list is used - all tracks (maybe even not displayed in source preset report), which satisfy source preset condition.
* LR presets can be chained to take advantage of multiple conditions.
4. LR preset report preview can be interactively filtered, according to specified condition, by clicking "Filter" button.
5. plugin settings are extended. simplified quick settings can be opened from some commands.
if somebody has ideas, for which ASR presets it might be useful to allow using <ALL TAGS> (along with generic tags, and considering possible restrictions to what to treat as "all tags"), post your suggestions!
download link:
https://www.mediafire.com/file/ycdl10fo8cgfwns/mb_TagTools_beta.zip/file
