The Plugin is very useful I see it now (Much appreciation 🫂) - rewriting the song titles to Spotify guidelines is a hassle without ASR
**My Problem.
1. I have set a hotkey to open the plug windows (Alt+D)
2. I have my custom Present
3. I checked the tick the assigning hotkey for the preset (hoping it is ALT+D)
Expectation: The preset would run to the selected tracks, silently without opening the ASR window
what should I do to reach the expectation?**I just realize most of the songs scrobble to LastFM are from Spotify (you can tell that cause Spotify does not use "( )" on remixes & other releases, Apple & Deezer does. Spotify uses " - " also is because
** I use the
"music bee sync to Service" plugin to sync Musicbee & spotify Playlist a lot
(SpoBee - I call that)
