Brilliant thanks.
Case insensitive would be great!
The only other thing I've noticed is that in the newer version I now get an error if I try and load "Library Reports". I know it's unrelated and it also happened in the version from earlier this month but if I roll back to the 2021 plugin it works.
MusicBee v3.4.8033.18564D
System.ArgumentException: Parameter is not valid.
at System.Drawing.Bitmap..ctor(String filename)
at MusicBeePlugin.LibraryReportsCommand.initializeForm()
at MusicBeePlugin.LibraryReportsCommand..ctor(Plugin tagToolsPluginParam)
at MusicBeePlugin.Plugin.libraryReportsEventHandler(Object sender, EventArgs e)
at #=ztdEURO9iLJryE.#=za3znDkU=(Object #=z09rm0$E=, EventArgs #=z5EKpxKY=)
