Hi boroda,
I am having several issues with ASR tool; both Change Case and Advanced Search & Replace. (Version 5.2 from Official Add-In page)
I'm unsure if there is something wrong with the tool, or possibly folder permissions on my PC but I have been unable to solve the problems.
There are two clear issues I'm having, and both seem to be related to the settings.xml located in user files:
Issue 1 - Change case ignoring some excepted words, but not others:
It seems that only words located in the default list under <exceptionWords> in mb_TagTools.Settings.xml work here.
If I delete/add a word such as 'and', 'for' or 'but' it will work, but other words are ignored (see example).
The word 'out' not being detected.
Removing the word 'and' causing it to change case as expected.
Issue 2 - 'Set as default for Advanced Search & Replace preset' buttons located in Change Case do not work:
Despite setting '(' as a character in 'Except for words after symbols' list or '-' as a word splitter and pressing the button ASR will ignore those settings.
I managed to set '-' as a word splitter by manually editing <wordSplittersASR> (default setting is 'ASR'), but was unable to get ASR to detect brackets, etc.
Any advice you can give on how I can solve this would be great.
Edit: It seems like I misunderstood and Word Breaks don't force a capital, is it possible to add this feature (for example first letter after a bracket is always capitalised)?
I'm still having issues with the change case tool not syncing settings to ASR correctly.
