phred, do you have any alr presets? do you have asr presets ticked for auto-applying? what happens if you disable all plugins except for at&rt?
Using AT&RT 5.2.7214 with MB 3.3.7257 P
I have no presets for library reports, nor have I used reports in quite some time.
I thought I had three or four ASR presets ticked, but only found one, which I disabled. Closed MB and restarted and MB froze.
I have disabled all plugins except AT&RT, shut down and restarted MB, performed a preset (change case) and ASR showed the changes, but never displayed 'close' or 'save' and only changed one of the left side boxes changed from a tick to a solid box and promptly froze. MB's status bar shows "Changing case: 100% (2 file(s)) read" when it hangs.
Please let me know what other information I can provide in order to help get this resolved.
Thanks.
