Regarding this, please add <Folder Name> too. Also it would be great if you can make those three fields (path, folder name, filename that all MB supports) available in other commands as well (copy tag, asr, etc.). I know I can easily construct those using virtual tags, but I'm really short of virtual tag slots.
its done
Thanks, but you added <filename> and <folder>. <folder> seems <path> that MB supports and still there's no <folder name>. Different field names could confuse users. Can you support the same three fields just as MB does?
So for a file E:\Music\Pop\abc.mp3
Path: E:\Music\Pop
Folder Name: Pop
Filename: abc.mp3
Another issue: Copy/paste selected tags command doesn't work for any file properties. And can you add <Path> & <Filename> too? Currently it only supports <URL> (though it's not working now), so the user has to use virtual tags for those.
file properties are read-only. what do you mean by <URL> is not working? that its read-only? could you give me an example of what you are trying to do?
Try selecting all file property tags using copy selected tags command and paste it to a text file. It copies nothing.
Also, tag sets don't remember any file property tags. Include some property tags to a set, and if you open the set next time, file property tags are all excluded. Looks like the command doesn't support copying file property tags at all.
Of course they are read-only. I'm using this to get information of tracks or to compare a large number of tracks by pasting it to a text file.
But is it not possible to write Album Gain and Track Gain tags to files?
