MSR command and presets are now working.
But if you hide MSR window and rerun the command, you get this error:
MusicBee v3.2.6671.32617 (Win10.0)
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.Collections.ArrayList.get_Item(Int32 index)
at System.Windows.Forms.DataGridViewColumnCollection.get_Item(Int32 index)
at System.Windows.Forms.DataGridView.FlushDisplayedChanged()
at System.Windows.Forms.DataGridView.PerformLayoutPrivate(Boolean useRowShortcut, Boolean computeVisibleRows, Boolean invalidInAdjustFillingColumns, Boolean repositionEditingControl)
at System.Windows.Forms.DataGridView.OnColumnCollectionChanged_PreNotification(CollectionChangeEventArgs ccea)
at System.Windows.Forms.DataGridViewColumnCollection.Clear()
at System.Windows.Forms.DataGridView.Dispose(Boolean disposing)
at System.ComponentModel.Component.Dispose()
at System.Windows.Forms.Control.Dispose(Boolean disposing)
at System.Windows.Forms.Form.Dispose(Boolean disposing)
at MusicBeePlugin.MultipleSearchReplaceCommand.Dispose(Boolean disposing)
at System.Windows.Forms.Form.Close()
at MusicBeePlugin.PluginWindowTemplate.display(Boolean modalForm)
at MusicBeePlugin.Plugin.multipleSearchReplaceEventHandler(Object sender, EventArgs e)
