- If you have not imported any ASR presets and try to save a MSR preset, then you get this error:
at MusicBeePlugin.AdvancedSearchAndReplaceCommand.Preset..ctor(Preset originalPreset, String presetNameSuffix, Boolean copyGuidIfsuffixAbsent)
at MusicBeePlugin.MultipleSearchReplaceCommand.saveButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
But once it starts working after you have imported presets, then it keeps working even if you have no imported presets.
- Case code still doesn't work.
If I use \@tc($1)
the saved preset also has \@tc($1)
So I have to use \\@tc($1)
then saved preset is working but MSR window still doesn't work (even preview is wrong).
- Checked escape sequences for meta-characters and all are working fine. Delete all button now doesn't delete custom presets plus MSR presets.
