Quote from: boroda74 on January 15, 2018, 05:35:09 PM'Reencode tag' command is replaced by 'Reencode tags' command. cuesheets are supported.Aside from the cuesheet issue, I don't really see much progress with this tool. It now supports only three tags: album artist, album, and title. Previously it was possible to fix other tags as well.
i can add 1 arbitrary selectable tag to display in the table. do you think its acceptable?
phred, i always disable persistent windows when i'm editing ui. its just a beta and it will fixed for stable release.
