Author Topic: Additional Tagging & Reporting Tools  (Read 937080 times)
Now they're all working great! Thank you for the update!
Something happened, probably related to changes in my screen resolution, and now when I try to run the Swap Tags command this is the box I get:
I can't resize it.  I've tried updating the plugin, disabling and enabling, etc, but it stays that size.  Any suggestions?
Try to click 'Uninstall' in plugins prefs. This should remove plugin settings. Then restart MB.
That got it, thanks!
timelezz
Hello, I try to use this plugin, but not with great success. I wish to replace snippets of text from the song title. Could someone guide me? For example: I want to remove the snippet "(Official Video)" from a song title. I've tried, but nothing happens. So obviously I do something wrong. Can someone explain what I should enter to make it work?
Ps. I did not read every single post here. Sorry when my question is already asked before.
  • MB Version: 3.6.8878 P
@ timelezz
using the Remove '(...)' or '[...]' from the end of '<Tag 1>' preset
change Tag 1 to Title
click Preview
if everything correct, click Apply
timelezz
Thank you, that worked!
And what can I do when I have a song title that says:  "Look Right Through (MK Remix) (Official Video) "  and I only want to remove the '(Official Video)' part?
Copy preset 'Remove '(...) or '[...]' from <Tag 1>' and search for
(.*?)\s*[\(\[][^\)\]]*?[\]\)]$
in <Tag 1>. Name new preset accordingly, click 'OK'. Apply new preset to appropriate tracks.
timelezz
Thank you. Isn't there a way to make it remove an (editable) set of given strings when they appear in the title?
MB's native Search & Replace (Under Tools> Tagging Tools) will do. Just leave empty for "replace with" part.
from here
Quote from: Steven
- support for the following predefined tags - see this topic
    Genres, Artists, Artists: Artist, Artists: Performer, Artists: Guest, Artists: Remixer
G'day boroda74
Just wanted to check if there will there be an update of the plugin to use these new tags?
No, they are currently not exposed in api.
Thanks for the info
I'll see if I can access them via a virtual tag
I'm going to add these new tags to my plugins on this weekend (thanks to Steven).
New plugin version is released
  • Added support for new tags (Genres, Artists, Artists: Artist, Artists: Performer, Artists: Guest, Artists: Remixer).
http://musicbee.wikia.com/wiki/Additional_Tagging_and_Reporting_Tools
MB latest update is required to use new tags:
http://musicbee.niblseed.com/V2_3/MusicBee_Exe_Patched.zip
Last Edit: January 19, 2014, 04:06:04 PM by boroda74
