Author Topic: Additional Tagging & Reporting Tools  (Read 937001 times)
Do you 'import all' or 'import new' ASR presets?
List of words is saved only if you click 'Proceed' button.
Maleko12
If I clicked on import all, it says "69 preset(s) was/were successfully imported." But nothing shows up. And a list of words are saved when I click proceed. But when I restart MB, they disappear.
Is there any error messages displayed when you import presets or exit MB (settings are saved to file on MB exit)?
Maleko12
Hmmmmm, didn't notice this until now. This keeps repeating around the time I use the plugin:
4/22/2013 8:16:57 AM - 6.1.7601.65536 - 2.1.4848.35226 - System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.InvalidOperationException: There was an error generating the XML document. ---> System.InvalidCastException: Specified cast is not valid.
   at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationWriterSavedSettingsType.Write7_SavedSettingsType(Object o)
   at System.Xml.Serialization.XmlSerializer.Serialize(XmlWriter xmlWriter, Object o, XmlSerializerNamespaces namespaces, String encodingStyle, String id)
   at System.Xml.Serialization.XmlSerializer.Serialize(TextWriter textWriter, Object o, XmlSerializerNamespaces namespaces)
   at MusicBeePlugin.Plugin.SaveSettings()
   at System.RuntimeMethodHandle._InvokeMethodFast(IRuntimeMethodInfo method, Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeType typeOwner)
   at System.RuntimeMethodHandle.InvokeMethodFast(IRuntimeMethodInfo method, Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeType typeOwner)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
   at #=quLLvjgdAE_Nbqv7HRl0cvqQWB2pnoxzHVLUwc4mHJKE=.#=qzRKLcqgbtCzWHxB2sX1UDA==()
First install latest plugin version, then go to edit>prefs>plugins>additional tagging tools, click 'unistall' and restart MB immediately to clear saved plugin settings.
Maleko12
I get this error when I try to uninstall it from the plugins section...
MusicBee v2.1.4860.34625 (Win6.1), 23 Apr 2013 0:46:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.IO.IOException: The process cannot access the file 'C:\Users\Mark Jr\AppData\Roaming\MusicBee\mb_TagTools.Settings.xml' because it is being used by another process.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.File.Delete(String path)
   at MusicBeePlugin.Plugin.Uninstall()
   at #=qEZFsCbHjVDNOvCg3YjPCSEtOFBh4LLpcTeHbTs2gLs8=.#=qBET49i1uhGv7Oji4taeuBg==()
The file is plugin settings. Strange that its locked by another process. Can you delete this file manually (first exit MB)?
Maleko12
I can delete this manually. But when I restart MB, instead of the plugin being uninstalled, it's still there, just being shown as disabled.
So I manually deleted all traces of this plugin (even went into MB's settings and removed the dll of the plugin), reinstalled it, and it's at the same situation.
Last Edit: April 23, 2013, 03:28:05 PM by Maleko12
Maleko12
OK, I uninstalled and reinstalled MB and downloaded your plugin again. Now it works!
VX
There is a bug with the latest stable plugin version and ASR Preset Editor.
I've translated recently added presets into Polish. When updating I clicked 'Save' button after every translated preset. When I finished I clicked 'Save all and Close' button, and then closed MB. After MB restart I can see ASR Preset Editor asking me to click 'OK' button for every preset I've updated.
After a few clicks 'OK' button the following error occurred:
MusicBee v2.1.4870.30402 (Win6.1), 4 maj 2013 15:05:
System.NullReferenceException: Odwo?anie do obiektu nie zosta?o ustawione na wyst?pienie obiektu.
   w MusicBeePlugin.ASRPresetEditor.saveSettings()
   w MusicBeePlugin.ASRPresetEditor.buttonOK_Click(Object sender, EventArgs e)
   w System.Windows.Forms.Control.OnClick(EventArgs e)
   w System.Windows.Forms.Button.OnClick(EventArgs e)
   w System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   w System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   w System.Windows.Forms.Control.WndProc(Message& m)
   w System.Windows.Forms.ButtonBase.WndProc(Message& m)
   w System.Windows.Forms.Button.WndProc(Message& m)
   w System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   w System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   w System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
I'll send updated presets to you in a while (check your email and confirm please). Not all translations were saved successfully, but I've made a copy in a plain text file so I can fix this easily.
Update:
Looks like the translations were saved, only the translated presets names remained in English, but when I clicked 'Rename/edit...' button both title and the description were in Polish, so I clicked 'OK' for every preset, then 'Save' and 'Save and close' button at the end.
Last Edit: May 04, 2013, 02:25:25 PM by VX
Cant reproduce this. Seems to be specific for your PC. Try uninstall & reinstall plugin.
New version of plugin released. See 1st post for details.
VX
I wonder if its possible to use ASR Presets for  batch "Mark as Having No Lyrics".
There are several requests for this feature on the forum:
http://getmusicbee.com/forum/index.php?topic=9207.0
http://getmusicbee.com/forum/index.php?topic=7735.0
http://getmusicbee.com/forum/index.php?topic=6026.0
It would be useful especially for:
audiobooks,
podcasts,
mp3 courses,
instrumental,
relaxation
or classical music.
What do you think  ???
