Author Topic: Additional Tagging & Reporting Tools  (Read 1154741 times)
just a small but easily fixed bug, ASR preset " add up to one zero to a group of digits in <tag 1>" currently adds "${text}" before the zero when using this preset.
thanks, i'll fix it. but you haven't answered if the previously reported MSR bug (not reproducible by me) is fixed.
Dizza17
My apologies, yes so far the latest update seems to have fixed that exception. Greatly appreciate your efforts.
Regards Aaron
When the rich wage war, it’s the poor who suffer.
Version 9.2 Update 7 (9.2.9141)
* ASR UI/UX bug fixes using skin colors.
* ASR presets "Add up to # leading zeros to first group of digits of <Tag 1>" have been fixed. Reinstall predefined ASR presets.
Full plugin package:
https://www.mediafire.com/file/dm3rhfze89n3qwi/Additional-Tagging-Tools-Plugin.zip/file
bkev
Hi @boroda thanks for continued support and upgrades to this great plugin.
I've installed the latest version but I still get the same error as @babydoll32 was getting with the message about the preset chain. I have tried to press "Install New" but the same thing still happens.
The weird thing is, the auto execute preset as well as the ones chained so still work.
no problems here:
and i don't understand how any related error could happen. note that you can't tick more than one preset from the same REAL preset chain for auto-execution. (tick only the first preset in a chain, then the entire chain will be auto-executed)
if the presets you are ticking indeed are not included in the same chain(s), then uncheck ALL presets and "delete all" predefined presets, "save all & close" ASR, close MB, and delete plugin settings file: <MB AppData>\mb_TagTools.settings.xml. start MB again, and "install all" predefined ASR presets. ctrl+click "save all & close", and retry ticking INDEPENDENT presets.
bkev
Thanks Boroda.
Here what I tried but still got an error.
Open MB, click "Delete All". I even deleted custom ones. Saved and closed MB. Deleted the <MB AppData>\mb_TagTools.settings.xml file. Open MB, Install All. Ctrl + click "Save all & close". I then pressed the tick to auto execute the "Replace acute and grave accents with apostrophes in <Tag 1>". Ctrl click save all and close and close the window anyway. Next time I open ASR, I get a pop up saying "One preset in the current preset chain is already ticked for auto-execution. You can't tick the current preset!"
thanks, bkev. i can reproduce this bug by reopening ASR window. (haven't tried to REopen it previously)
bkev
Brilliant thanks boroda. That has fixed it for me. I've unchained the presets and just selected each one and I no longer get any errors and they show as ticked when I reopen the window with no error :)
Just wondering, was a cake send to boroda when 1 million views was reached?
Ah well, here's mine:
Thanks for creating, improving, and the continuing support of your Additional Tagging & Reporting Tools plugin boroda!
(about the image: I wanted to credit the creator, but I think it was created by some AI, so I can't credit an actual person for it)
Congrats boroda! That's quite impressive. I am still of the opinion that AT&RT is the most downloaded and most used plug-in for MB. Thanks for all the effort you've put in to it.
hmm, i haven't noticed this. but no, there was no cake.
i don't know this. but this actually doesn't matter. i don't intend to create "the most downloaded plugin". i'm just satisfied if it's useful for somebody.
I know you didn't set  out to create the most popular plugin. But you did. It just shows how useful it has become for MB users. Now you can go have some of that HoneyMusicBee cake hiccup provided.
