Author Topic: Additional Tagging & Reporting Tools  (Read 936488 times)
foxj
I have also been getting an error with this plugin. MusicBee will disable it when it starts.
If I try to manually start it I will get this  ERROR
Both portable and installed versions 3.3. and 3.4 on win 10. (3.3.7310 & 3.3.7261)
Where does it put its log in the portable version?
Last Edit: January 15, 2020, 06:48:38 PM by foxj
This might be a security issue. Whitelist your entire MB directory and try again.
close mb, then delete file <mb appdata>\mb_tagtools.settings.xml
foxj
That worked thank you
Possibly because I copied it from the MusicBee installed version to the portable version?
asdasdasd223
For some reason, it randomly stopped showing up in the drop-down menu. I reinstalled and saw that all the files were still there... I replaced everything and now I'm getting this error every time I open MusicBee: "Some tag names are duplicated"
When I try to use one of the advanced tagging tools, I get this error.
What version of MB are you using?
Completely uninstall the plugin, completely exit out of MB. The relaunch MB and reinstall the plugin.
fjelsten
Hello
I believe there used to be a help page for advanced search and replace but I can no longer find it.
Anyway I would really like to automatically add episode date (not time!) to the start of the existing podcast title. I understand I can use something like this:
$Date(<Episode Date>,MM-dd) <Title> in organizing podcasts, but I cannot seem to be able to use $Date(<Episode Date>,MM-dd) in the ASR.
In addition, I have been unable to get some RegExp to work that fetches the first 5 characters file name (that due to the organization above does have the month and date).
Could anyone point me in the right direction?
(I understand that creating a dynamic playlist I can get the tag updates to run automatically on only my podcasts - and I have created an auto playlist that only finds relevant podcasts)
this means that plugin requires that all tag names must be unique. go to edit> prefs> tags(2)> configure fields. make all tag names unique.
Hello
create virtual tag with formula $Date(<Episode Date>,MM-dd) and use it in ASR.
fjelsten
Thank you!
Works well now. I actually had a virtual tag before but I could not get it to work in ASR.
Which settings in ASR do I need to make sure that this is applied to new podcasts as they are downloaded? Do I just need to tick it (I have already made an auto playlist for podcasts less than 30 days - but that also included those that are already updated)?
asr can auto-apply presets to new tracks *and* existing tracks if any tag is changed. but you can assign virtual tag function id for any preset and use that preset function in a *virtual* tag (which is not stored at all).
fjelsten
I set it to auto-apply, but it keeps looping (each time ASR has added the episode to the start of the tag, (the tag is updated),it re-applies, and again, and again, ...)
How do I prevent this?
http://www.mediafire.com/file/h2t08o9562efboi/mb_TagTools_latest.zip/file
